View Poll Results: Did you modify your 2055's before installation?
No, just installed them as-received
76.92%
Yes, just opened up the ball flange
7.69%
Yes, fit checked the y-pipe and opened up the ball flange to match
15.38%
Voters: 13. You may not vote on this poll
Hooker 2055 users: Modifed- Yes or No?
Old May 7, 2005 | 07:59 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Curious how many of you opened up the ball flange when you installed.
Really curious if anyone has performance data from unmodified before to modified after...
Old May 7, 2005 | 09:23 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I really didn't have much chance to open it up. They fitment was questionable, and on the drivers side, the ball flange is so crooked, it is almost imposible to fit right. had I bolted it together off the car, and opened them up, it would not have worked once I got it on the car.
Old May 7, 2005 | 11:16 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Mine just went it like it belonged there.
Old May 7, 2005 | 03:12 PM
five7kid's Avatar
Perhaps I should clarify: I'm talking about the 1.9" or so opening they leave at the collector ball flange.
Old May 7, 2005 | 05:25 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I woosed out and just installed mine. I was too afraid of screwing up my $500 + investment. They said they would not take them back if you modified them and there was a problem.
Old May 7, 2005 | 11:04 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Mine are box stock also
Old May 8, 2005 | 01:33 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i opened mine up. i could not install a header with such a small outlet. it looks like the stock manifold outlet...yuck.
Old May 10, 2005 | 10:09 AM
305PhoenixAm's Avatar
Car: 85 Trans Am
Engine: 383 TPI (Yes, TPI. Not for long though)
I'm going to be opening mine up next time I get on a lift. Too small. Figured it'd be easier with the carbon deposits already there as a template.
By the way, about how wide is the diameter once you opened it up?
Old May 10, 2005 | 10:39 AM
five7kid's Avatar
About 2-1/8" - 2-1/4". The downpipes are 2-1/2" OD, which makes the ID about an 1/8 of an inch less, but I didn't shoot for the max. When it's apart for the 350 shortblock, I'm going to open it up to the carbon marks. I'll measure then.
Old May 11, 2005 | 03:40 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
five7 i dont know if you recall, but i also opened the ball flange up... hell might as well while everythings new and easy to work with, but i had mine on a lift so that made it easier.. opened it up as much as possible before we put on the ypipe, fit checked first of course and stenciled lines with a pencil for the cuts.
more flow = better
Old May 12, 2005 | 10:01 AM
five7kid's Avatar
More flow doesn't always equal better. Since exhaust comes out in pulses, you can over-do it. I don't think that's the case here, but we need to be sure we understand the conditions before we assume things such as that.
Without any performance data, for all I know Hooker could have done the right thing. I don't think so, and their response to my inquiry about that small opening talked about better sealing and gas speed having dropped by the time it gets to the collector. If they had said the small opening works better than a large one, that would have been a different story.
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
