o2 sensor won't give
Old May 15, 2005 | 05:53 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
My o2 sensor was gone so i bought a new one and now i can't get the old one off. Tried combo wrench, tried socket wrench and i even tried a heavy duty impact wrench, and the sob won't give. Any suggestions? Can the car run for a while with out it?
Old May 15, 2005 | 08:08 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Have you soked it in PB blaster? That stuff is a amzing and should soak into the threads enough to allow you to break it loose. You may also want to try to heat it up. I would soak and soakl and soak it in PB blaster hours before your next attempt. Your car will run without it but it will hate you for it.
Cornholio7979
Sep 20, 2018 02:31 AM
Logan Bryant
Aug 27, 2015 11:52 AM
L98GTA87
Aug 25, 2015 02:23 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
