Help Me Find An Exhaust
Old Jun 22, 2005 | 03:35 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
I'm having a hell of a time finding a decent exhaust system for my 1982 trans am. I went to jegs.com and looked into a Borla Exhaust but then found out that they misprinted the year and that it was only good for 1984 and newer. Im intrested in getting a duel exhaust system. If anyone can direct me to any links that have exhausts for a 1982 Trans Am it would be greatly appreciated...My car thanks you
Old Jun 22, 2005 | 04:12 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
they dont make dual systems for thirdgen's.. you will have to custom make it yourself.
it looks to me like you are just looking for a CAT BACK system..
in this case.. i would say look at
Hooker
Dynomax
MagnaFlow
FlowMaster
what engine size do you have, do you have headers or an upgraded CAT yet?
Old Jun 22, 2005 | 05:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, there is a dual system made by Dynomax - it is semi-custom (some frabrication may be required), hangs down, puts the mufflers in a place where they don't really fit under the car, and is 2-1/4".
Old Jun 23, 2005 | 12:09 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
i have headers installed but im going to replace them with ceramic coated hooker headers. My engine is a 305 v8. It currently has a custom duel exhaust on it from the previous owner, but it has to be 20 years old.
Old Jun 23, 2005 | 01:17 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Well then just replace the old pipes with new ones? Duals are the best flowing and the best sounding exhaust system you'll find.
Old Jun 23, 2005 | 01:56 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
I think I'll bring it to meineke and have them replace the pipes and mufflers. Is there anything specific I should ask for when they're replacing the pipes (like the type of metal). I want to get the best possible.
Old Jun 23, 2005 | 05:24 PM
sellmanb's Avatar
Car: '86 Berlinetta
if there's gunna be a curve or turn on the pipes make sure they're mandrel bent, not crimped or cut and welded at the proper angle.... which is what you should expect if you take it there....
Old Jun 24, 2005 | 12:12 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
the hooker catback sounds awsome, and flows very well. $297-jegs...
eightsixseven
Dec 16, 2024 01:50 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
gta power
Aug 13, 2015 06:15 AM
