custom Y pipe questions
Old Jul 4, 2005 | 08:50 AM
theboilermaker's Avatar
Car: 87 camaro sc
Engine: 357 w/ cc qjet
Transmission: 700 r4
I am making a Y pipe for my hedman shorty headers with a 3" collector. I don't know wether to make the whole thing 3", or if I should make the pipe out of two 2.5" pipes that converge into a 3" pipe. What is the general opinion? Is 3" going to give me clearance problems?
Old Jul 4, 2005 | 11:23 AM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
2.5" to a 3" collector will be fine. Most people are running a 3" and have no problem, some are running 4" with no clearance issues so you should be fine.
Old Jul 4, 2005 | 06:16 PM
Car: 87 camaro sc
Do I gain anything going to 3"? It seems to me the only thing I will gain is clearance problems!
Old Jul 4, 2005 | 07:11 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Question? At the collector point of the headers is the hole opening 2 1/2 inches or 3 inches. That will tell you what size to make the pipes into the "Y" pipe. Usually they are 2 1/2 inches. Make sure the header opening is not closed in by sloppy welding or forming. If so grind it out or you will loose HP. Same where the header mounts to the head.
Saw a pair of headers over the weekend from a reputable company and the hole size at the collector was only 1 3/4 inches due to the way it was formed. That was barely bigger than one header by itself. Otherwise the headers were well made and looked good. The owner had them opened up to 2 1/2 inches.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
midias
Aug 22, 2015 01:42 AM
redmaroz
Aug 16, 2015 11:40 PM
