best headers for $300 to $400
Car: 1992 rs
Engine: 350 tbi
my car has an exhuast leak at the stick manifold and i figured now would be a good time to get sum headers. what would be my best choice for around 300 to 400 dollars without air tubes but that comes with a y pipe? i am looking for primary sizes of one and fice eights or one and seven eights
Car: 92 Z28
Engine: Boosted LSX
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
SLP would be the only ones without an AIR tube. You may want to look at the macs which have a less obtrusive AIR pipe and or modifying a set of Hooker 2055's. Those three are the best headers for the money. Certain hedmans would be a close second.
Transmission: 4L80E/4L80E
You can get Hedmans w/o A.I.R., and a y-pipe to fit them (at least, they are supposed to have fixed their mis-match problem).
But, I'll cast my vote for 2055's. Best y-pipe out there - compare the pic in the link above to the Hooker below. Y-pipe remains 3" after the two sides come together, nobody else's y-pipe does that.
You can also cut off the A.I.R. tubes and weld them shut. Just do that before coating if you decide to do ceramic (ups the expense, but well worth it).
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
