Cat interchangeability
Old Jul 19, 2005 | 11:01 PM
CDNMARO's Avatar
Car: 87 Camaro SC
Transmission: 5-Speed
Hoping someone can help, did a search & couldn't find an answer
Trying to get my car back on the road after swapping in a 305tpi... I need a new cat & found there's a serious price difference between direct fit cats.
A cat for a 305TBI is $135 while a cat for a 305TPI is $295.
Can I use the TBI cat on my TPI motor with out running into problems?
The car has to go thru emissions testing, otherwise I'd ditch the cat
Old Jul 19, 2005 | 11:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you swap in the TPI exhaust? If not, then the cheaper cat will work. If you did, get the TPI cat.
The TPI cat is about US$120 from Summit (CTO-9118), not sure what that translates to by the time it reaches your door.
Old Jul 20, 2005 | 12:42 AM
CDNMARO's Avatar
Car: 87 Camaro SC
nope didn't swap the exhaust... come to think of it, the cat back system is still the V6 stuff (High Flow I'm sure) :-S. Tho it does have headers.
Maybe I'll just stick to the universal fit cat & patch in the difference
Old Jul 20, 2005 | 09:38 AM
five7kid's Avatar
What headers?
Old Jul 21, 2005 | 02:14 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
You could always try ebay, I got a set of cats for my carbed engine for $35 each.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
