header fit
Old Aug 16, 2005 | 11:15 PM
cuda69's Avatar
Car: 91z28vert,3:42posi-rear,gu6
Engine: 305TPI
Transmission: T-5,pro5.0 shifter
header fit
can anyone tell me if a pair of hooker 2055`s will fit my z28,i have a stock 305 tpi with a single cat,i have a chance to buy a used set and need to know if they will fit my stock cat,also do i need any accesories for the install,like flanges or collectors,this would be my first exhuast work and need all help i can get,thanks,also anyone know what size tube ends are on stock z exhuast from factory are they 2 1/4 in dia.?the end that bolts up to the ypipe to the cat whats the inlet dia for stock pipe on a91 z28 with single cat?
Old Aug 17, 2005 | 12:40 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
They will fit your car as far as fitting your cat they wont. The outlet at the end of the y-pipe is a 3" slip fit. You can get 3" universal cats pretty cheap off eBay. You will have to modify your a/c bracket and you will have to make or rig something to hold you oil dipstick in place.
Old Aug 17, 2005 | 10:21 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: header fit
2-1/4".
Pretty sick, huh?
Street Lethal
Apr 30, 2019 12:14 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
Wvcamaro
Sep 4, 2015 08:38 PM
LilHot
Aug 23, 2015 09:36 PM
theurge
Aug 21, 2015 12:46 PM
