Better mpg with Headers, yes or no?
Old Sep 10, 2005 | 04:32 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
In general I hear that headers increase gas mileage, but in other posts I hear they make mpg worse.
I want more power, but I don't drive crazy and I try to get the best gas mileage as possible. Usually around 240-250 with my cutout open.
So I am wanting headers, but I want to know what to expect with MPG.
Thanks.
Old Sep 10, 2005 | 05:32 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
usually an increase of power in the car will give you better gas mileage, unless it's an increase that demands more fuel.
You'll probably gain slightly (1mpg or less) or stay the same.
Old Sep 11, 2005 | 12:46 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My 350 gained a whole lot of power, but the gas mileage stayed the same, at about 12mpg.
Old Sep 11, 2005 | 07:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They will add power and should help your milegae provided you do the chip work to dial them in. I am not sure about TPI cars but TBI cars can see an increase in VE by up to 10% with a set of headers. That requires chip work to dial everything back in. Without the chip work you will have a little more power but you will also likely have worse fuel economy. With chip work you can have both. This may be different for TPI cars though.
Old Sep 11, 2005 | 12:37 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
On my 88 I have headers, high flow 3" cat, Dynomax exhaust, K&N filters, air foil, 3:23 rear gear with the L98 engine. Just took a highway trip and got 24. 1 mpg average. Pretty satisfied with that if only the tank was bigger.
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
ssgt usaf
Sep 21, 2015 12:45 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
