stock exhaust size
Car: 85 bird
Engine: 305 4bbl
Transmission: 700R
stock exhaust size
i have an 1985 firebird 4bbl 305 im replacing the cat with a straight pipe but i don't know how big the stock pipe is is it 2 1/4 or 2 1/2
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
2 1/4 all around... did the same exact thing a while back... sounded better in my application, didn't trigger SES light either.
Good luck,
Brandon
Good luck,
Brandon
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
LG4 (base 4bbl 305) had 2.25" I think. The L69 (305 4bbl HO) had 2.75" pipes.
Re: stock exhaust size
I just finished doing the exact same thing. Removed the old cat, y pipe, and manifolds. I upgraded to manifolds and y pipe off of a '91 iroc, the y pipe outlet was 3". I had to get a pipe made that went from 3" - 2 1/4" at the rear pipe. Sounds really nice this way and I noticed as well that no ses/eng light has come on.. very pleasing
). I'm trying to figure out what kind of HP you get from such a mod. As well as removing the A/C compressor and lines.
). I'm trying to figure out what kind of HP you get from such a mod. As well as removing the A/C compressor and lines. Junior Member
Car: 1986 trans am
Engine: 305 with almost 2000000 on it!!
Transmission: 700 r4
i actually have a similar question, i bought an 86 trans am 305 engine and has tpi, whoever owned it before me tore this car apart, i am trying to figure out what the stock exhaust was on it because i believe i am not getting the proper back pressure for it. it has a single exhaust pipe and where the two pipe come into one it is 3" the entire way back with a "super turbo" exhaust pipe at the end. like it said i an just trying to play mad scientist and put this car back together the way it was meant to be!! so any help would be apreiciated
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
