Hole in exhaust?
Old Nov 19, 2005 | 09:58 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Hole in exhaust?
When idling there is a strong smell of exhaust in my car... when driving and let off throttle there is sort of a popping noise coming form what soudns liek the exhaust
any ideas on getting a deeper sound out of single into dual? i mean.. header to y pipe to single to flowmaster muffler with dual outlets? i heard a high flow cat is the key for those
Old Nov 24, 2005 | 12:29 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
that sound youre hearing is pretty normal. your engine is being forced through the power stroke at faster than it would be if you just revved it in neutral.
i would worry about a strong smell of exhasut unless its with your windows up. that is, unless you have the "vent" on your AC panel on. if it's coming through the ac vents, you may have a leak under the hood
you want deeper sound? go with a cutout. mine has a mccord power plate on it and i love it.
Old Nov 24, 2005 | 01:55 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Seconded. I also have a MPP and I love it as well. But the only thing about that is that it's just raw sound and no tone. I'm thinking of welding a spiral muffler to the end of it.
The popping sounds about right to me. Like it's backfiring a litle bit. My '87 v6 did that all the time. It's just the sound of teh spark plugs firing, I think. I'd say the exhaust smell is unrelated. To you hear any ticking coming from under the hood?
Old Nov 24, 2005 | 02:34 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
if you're referring to a popping after you let off the pedal, it's caused by the car running slightly rich, and the gas is rapidly expanding in the pipes. Nothing to worry about in that case usually.
The smell may very well be a leak somewhere. Have a look/listen around with the car running and you should be able to find it.
Old Nov 24, 2005 | 11:24 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
no ticking noise... its the worst when its cold... when it is warm outside than there is no smell. so im not to worried about it
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
