Exhaust casting numbers needed
I am looking for 1991 305cid exhaust manifold casting numbers. Can anyone pass this along?
I don't think there is a difference between the TPI and TBI cars, but please correct me if I'm wrong.
Andrew
Andrew
Transmission: 4L80E/4L80E
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I have an 87 LB9 with G92 and a single CAT. The stock manifolds are part numbers 14094063 & 14094064 and measure 2.19 inches inside diameter of the outputs. I'm not sure if they are what you are looking for....
Thanks mnorton and five7...
If there is no difference between TBI and TPI cars, then your part number would be what I am looking for, but after reading throuhg five7kids thread-link I am confused... G92 TPI cars 305cid with the dual cats, did they have different exhaust manifolds? They did have a different exhaust set up, and this is how they gain the added hp#... but was this just based on the two cats under the car, or where the exhausta manifolds indeed different?
ANyone else have any info
-ANdrew
-ANdrew
Engine: 305 LB9 TPI
1992 Trans Am
May 10, 2023 07:19 PM
