Hooker 2055's
Old Dec 3, 2005 | 05:32 PM
mj14sports's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI L03
Hooker 2055's
I wanted to get a set of headers for my 91 camaro 305 TBI and have read around here to decide what kind to get. I saw that the Hooker 2055's seemed popular and decided to check them out. Well why does everywhere I go say that they only fit up to the 1990 camaro? Is there a difference between the 1990 305 and the 1991 305? Any help would be appreciated.
Old Dec 4, 2005 | 01:43 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
The 2055s will work. No difference.
Old Dec 4, 2005 | 02:39 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I think that's talking about the dual cat cars, for an RS it doesn't pertain to you.
Old Dec 6, 2005 | 06:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The specific application for 2055's is '86-'90 TPI single cat. That's the cars that they will bolt onto and directly into the factory exhaust system.
If your car is not within that application, they will still bolt to your engine (if a Gen I SBC with factory type ports, and probably Gen II), and will fit the chassis. However, they will not bolt to your existing factory exhaust (or aftermarket replacement of factory type exhaust) without modification.
So, if your application does not fit within the confines of the above noted, then you will either have to modify your existing exhaust, or replace the rest of the exhaust with parts for the same application as the 2055's.
Hope that helps. That's pretty much the way I describe it every time the subject comes up.
Old Dec 6, 2005 | 06:50 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I have the Hooker 2055 and all i had to do was go to a muffler shop and have them weld in a new cat to the y-pipe and that was final. By the way there AWESOME!!
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
