air tube header question
Old Dec 4, 2005 | 08:07 PM
aroc's Avatar
I was wanting to put a set of A.I.R. compatable headers on a 1992 camaro with a 305. I looked at some flowtech and the hooker 2055. Both of these require modifying the a/c bracket. Is there a model/brand that is A.I.R. tube compatable that does not require bracket modification?
Old Dec 4, 2005 | 10:30 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Re: air tube header question
I don't if modification is neccesary on the following but Hedman and Edelbrock offer Headers with AIR tubes.
I know the Eldelbrocks are called TES headers.
Old Dec 6, 2005 | 03:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
No mods needed on the Hedmann 68470 or 68478 - you just have to get a 1 1/14 inch spacer from Home Depot for the lower brace that attaches to the header bolt - same with the power steering brace on the driver side - you use the old exhaust mani bolt, but put this spacer in to extend the bolt area where the brace attaches.
However, the Hedmann y-pipe doesn't quite work with the Elite (68478) header - but it comes with collector adapters that can be welded onto the y-pipe ends to extend them and make it fit well - the y-pipe seemed to be about 1 inch short in reaching the collectors on my 1992 - but this did the trick. I had no problems with the 68470's on my 1990.
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
drathaar907
Aug 6, 2015 04:20 PM
