True dual w/ SLP Loud Mouth mufflers?
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
ok i want to redo ym whole exhaust system on my T/A since now i finaly have my new motor in! Right now i have stock lg4 manifolds/ ypipe 2 1/2 catco cat and 2 1/2 non manderal bent I-pipe in to flowwaster 80series. I already know im gona use the Hedman longtubes and i was wanting o mabey do something similar to what "deadbird" has on his car as in the way its set up but im ust debating on the trye/ brand mufflers i want. I had wondered how it would sound w/ the Loudmouth mufflers on each side instead of bullits or flows. i want something Loud but a good kind of loud it anyone understands me. How would a set op like this work/sound? Any ideas/ sugestioins would be wonderful!!
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
if you're looking for a "good" kind of loud, I'd pick bullet mufflers over the LM any day. the LM is just an extremely overpriced peice of pipe. If you've ever seen one you'll understand immediately what I mean. The bullet actually does a very decent amount of toneing and just makes it scream.
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
i just finished that. did hooker LTs 1 7/8 into an X pipe and as my bullets, i got 2 Loud mouth resonators. so far, i like it
i wa thinking that it would prob be just a tad too loud but just wanted to throw the idea out there i had also thought about doing something like deadbirds but instead of using bullits or something home made like he did i had thought about the chambered tube mufflers like willie used in his setup but either have them coming straight out the back w/ some tips or once the pipes come over the axel put a 90deg bend and set them up like the marrows from the 60's. Hey
AZ406TPI u got any sound clips or pics? tanks guys your info is a big help please keep it comin
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
no, but it is loud. gotta remember, all it really is, is 2 resonators. i can try 1 off my cell phone, but im thinking that sound quality will suck
ye the quality of the sound will mre than likely be very poor and just loud
88SS6SPEED
Nov 11, 2015 07:05 AM
