CAT GLowin RED!
Old Dec 19, 2005 | 07:17 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
CAT GLowin RED!
I WAs WArming UP My Car, And SOmething made me get down and look under it, and i seen that the catalytic converted was glowing red at the end where the 3 inch exhaust pipe begins, what should i do? replace it?
Old Dec 19, 2005 | 07:53 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Sounds like it might be running lean.
Old Dec 19, 2005 | 08:47 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
yes you must replace it but first fix what caused the problem so you dont just **** away the new one and running lean could be the problem
Old Dec 31, 2005 | 12:06 AM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
sounds like your cat is deffenitly gone. but before replaceing it , you got to find teh problem that casued the cat to go out in teh first place, other wise your just gonna waist your money on a another cat, check you H2 sensor. and your iem sensor . have you done a error code check yet?
92firebirdguy
Sep 1, 2016 07:53 AM
PurelyPMD
May 5, 2016 04:57 PM
2012sergen11
Oct 13, 2015 07:38 PM
Dragonsys
Sep 25, 2015 03:51 PM
Eric-86sc
Sep 22, 2015 08:25 PM
