TBI Catback
Car: 2001 SS
Engine: bolt on LS1
TBI Catback
Does any one know if a 2.5" converter and catback will bolt up to 89 rs with a TBI 305 without changing the Y pipe?
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
Originally posted by kingdaddy305
How much extra should it cost becuase the quote was $467 installed and I dont want to spend $500 on a catback?
You can always buy the adapter yourself from any auto parts store and just point to the object of where you want it installed...and, I think that if they were to do the adaption, they shouldnt charge you any more than what was quoted...all it is a piece of metal enlarged..
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
If i get a 3 inch cat to go along with a 3 in TPI catback, how would it attach to my 2.25 y pipe? Would this cause problems or can the person whose installing it use a reducer or something?
Car: 1998 Volvo S70
Again the shop will make an adapter to fit it onto the y-pipe, there are ways to bypass things like this. I mean look at me, I managed to fit a 3 inch muffler onto my stock i-pipe and stock tail pipe....They use adapters for these things...
Car: 2001 SS
Engine: bolt on LS1
Thanks for the help, Ill check it out monday. Should a 80 series flowmaster sound good?(tired of Hondas being louder than me)
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would buy a tailored TBI cat-back ($350) and either install it yourself or call around and get a price. Most TBI cat-backs are 3" have have the 2.25" reducer already implemented on the end of the y-pipe for proper cat allignment/hookup. These kits can be installed with simple hand tools and any exhaust shop should be able to install it for less than $100. "Home made" exhaust shop cat-backs are junk and will not provided the nice 3" smooth mandrel pipes that you really want.
If you want a full 3" system down the road than you can just cut off the reducer and weld/slip in a 3" cat. If you are going with the whole shebang right now I would buy a cat, cat-back and header kit desinged for a '86 or later TPI car. This way it will all be 3" without any reducers.
