Installing headers
Old Jan 15, 2006 | 10:14 AM
Kaas's Avatar
Car: 89 Iroc-Z
Installing headers
Ok guys, i know this is a stupid question, but what is the best way to install some shorty headers on a third gen with A.I.R.
Am i going to need a torque wrench for this? And also, will i need to weld the Y-Pipe when it gets down towards the cat?
Old Jan 15, 2006 | 12:26 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
The best way? I'm sure there are more than a few threads about it laying around, but if I recall correctly it's pretty straight forward. Take the old manifolds off and slip those in. You might have to unbolt the engine on one side from the motor mount and jack it up an inch to give yourself some more clearance.
Take a look on your Y-pipe and see if it came with a flange to bolt to the cat or not. That will answer your question. Most likely it's flanged and simply needs to be bolted.
Old Jan 15, 2006 | 12:36 PM
91Z28-350's Avatar
I jacked up both sides, in turn. Had to unbolt the tranny mount too. The "higher" you get it up the easier it is to slip in.
Torque wrench would be nice. I used a crow's foot and a torque wrench.
Weld, up to you. You can use band clamps too.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
