Hooker 2210 y pipe?
Old Jan 18, 2006 | 04:50 PM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
Axle/Gears: 4.11 12 bolt
Hooker 2210 y pipe?
i have a set of 2210's, but after doing a search, ive read that the mufflex y pipe will have clearance issues and will need to be fitted etc. is there any other y pipe that can bolt on with out hassles?
im also fixing to get a 3 inch exhaust.
Old Jan 18, 2006 | 05:39 PM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Re: Hooker 2210 y pipe?
You will have issues with the mufflex y-pipe if your car is dropped.
I've never had any issues and I installed mine myself and then welded it all together.
Old Jan 21, 2006 | 07:50 PM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
is thats a 3' y pipe and a custom made I -pipe?
Old Jan 24, 2006 | 11:09 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
I just installed a Mufflex Y to my 2210's and it bolted up just fine without any modifications.
Old Jan 27, 2006 | 08:09 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
that sure is sharp, now they need to make one for hedman lt's...
Old Jan 30, 2006 | 02:12 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
So what is the part number to that, and how much extra would it be for a shop to fab up something to the muffler?
Old Jan 30, 2006 | 09:15 AM
part number is TPI-Y or TPI-Y O2 if you are getting it with O2 sensor bungs already welded on. http://www.mufflex-performance.com/fbody_8.html. Mine bolted right up. HTH
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
