305 to 350. Need Help with exhaust options
Old Feb 16, 2006 | 09:28 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Just did the famous 305 TBI to 350 TBI swap. I have stock 305 exhaust on it right now with a V force muffler (like flowmaster). Need to know what i should do about my exhaust manifolds.
1. Should I put on Headers? If so which ones for less than $200????
2. Can i use stock 350 manifolds? If so off which vehicle???
Thanks guys
Old Feb 16, 2006 | 09:32 PM
dctrumpet's Avatar
Update: It's a 1992 Firebird initially a 305 tbi. Thanks!
Old Feb 16, 2006 | 09:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you don't have to pass emitions, then use Hedman 68470 headers. They are 1-5/8" shorties, that do have an available Y-pipe for them. The headers themselves, with just the black paint, cost around $140 or so. I don't remember what the Y-pipe cost, but it wasn't too bad either. I use these on my 350 and they are great!
Old Feb 16, 2006 | 10:04 PM
dctrumpet's Avatar
Thanks for the great info. Appreciated! I assume i can leave the cat on or not? With headers to i have to take off the air tubes that are on my current manifolds along with the rest of the emissions stuff?
ALso, I have heard of a few who have drilled holes in their manifolds and reinstalled the air tubes, lol. Sounds pointless, but is it practical?
Old Feb 16, 2006 | 11:11 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
ditch the air tubes and air system and just put on those headmann shorties and a y-pipe with a nice 3" cat and 3" catback exhaust of your choice. Also jump on the chicago board and say hello to your local members.
Old Feb 17, 2006 | 08:52 AM
dctrumpet's Avatar
xpndbl3
Thanks man! lol. Will join the Chicago group. How do i do that????
Old Feb 17, 2006 | 12:15 PM
Air_Adam's Avatar
The Hedman headers don't have AIR tubes. Thats why I said "if you don't have to pass emitions".... because they wont, because of the lack of AIR tubes
They are a VERY good setup IMO, especially for the price, but there is one small mod you should do to get the most out of the system when you get it. The Y-pipe sends the two pipes off the headers into a collector that goes into a 2.5" pipe, which isn't very good for performance. The cure is easy though. Right in the middle of the "collector" on the Y-pipe, cut it off. Then you will have a nice 3" outlet to hook your exhaust system up to. Any exhaust shop should be able to make you a 3" pipe to go in place of the 2.5" peice, and weld it to your Y-pipe, for very little. Thats what I did.
If you decide you don't want to cut the Y-pipe, you may lose a few HP, but not much (of course, this depends on how hot the engine is too). No big deal
Vintageracer
Jan 10, 2020 05:33 PM
Keith5
Aug 27, 2015 04:37 PM
makaveli09
Aug 12, 2015 09:07 PM
marcusaw
Aug 10, 2015 08:13 AM
mustangman65_79
Aug 8, 2015 01:18 AM
