Bolts from the exhaust manafold keeps coming loose
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
No mather how hard I tighten them, they still come loose. anything I can do to keep them tight?
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Your manifolds should have come with these little tabs that went around the bolts. Once you got them as tight as you needed, the tabs bent up and prevented the bolts from backing out.
Another thing to check is the bolt(s) that keeps coming loose. Is the hole obstructed? If there is something in there, they are not going to get as tight as you need them.
Just a few ideas off the top of my head. Oh yeah, the tab things can be picked up at the dealer and could possibly be picked up at your local parts place.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Originally posted by magadith
What about that Thread lock glue stuff. Anyone tried that?
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
