Inside my hedmans
Old Mar 10, 2006 | 11:13 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Inside my hedmans
On the inside of my Hedman headers, the air tubes come down like half way into the opening of each primary. Would it be effective to grind it down until its flush with the top of the primary?
Old Mar 11, 2006 | 12:35 PM
RArnold's Avatar
Car: 1984 Camaro conv
Engine: 350, .040, warmed up
probably not.....Hedman designed the headers to work the way they are built..............
Old Mar 11, 2006 | 01:33 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It's been done many times, honestly I doubt its worth the effort but you've nothing to lose. Ever consider removing AIR? I removed mine and in MA we're strict about emissions yet I still passed.
Old Mar 11, 2006 | 01:35 PM
Engine: LB9, LB9
Well I wanted to remove AIR but then I found out that I will foul out my brand new catco cat because of unburnt gasses. and kinda got turned off by that.
Old Mar 11, 2006 | 01:41 PM
Car: 86 T/A
Engine: HSR 355
I doubt it'll foul your cat. I've heard issues about that, but I know alot of people who've driven 30K + miles without problems.
Old Mar 14, 2006 | 11:49 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
As far as the AIR tubes protruding into the primaries.... I'd grind them down since it's not that hard to do.
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
