2.5" for 305, too small?
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Ive got an LO3 with a flowmaster 40 series crossflow muffler. It's 2.5" in and out. It appears the rest of the exhaust is also 2.5" Theres no cat and stock manifolds are in place. Im thinking about getting Hooker 2055's with the y pipe sometime soon. Will this setup flow enough for my motor, or do I need to replace everything and go 3". I dont have the cash to replace it all at once, but would like to put on headers by mid summer. Im NOT absolutly positive it has a cam in it, if it does, it's a very mild one. I was told it might, but Im not going to pull it out just to check. Next year I am also thinking about the possibilty of intake, larger cam, and maybe heads too.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by MKnight
You don't need a 3" exhaust, hell I wouldn't even do that on a 350.
A 3" exhaust really is too small for most V8 motors. A 3" is a good mix between flow area and ease of fitment. That is why the aftermarket tailors their systems that way. How can you say that you wouldn't run a 3" system on a 350 when there are 397484937584 dyno tests out there, on stock V8's produced over the last 30 years, that say otherwise? If you are refering to a true 3" dual system than your statement would hold some merit.
A 3" exhaust will be benificial to you down the raod. The 2.5" system that you have now will suffice but there would be gains with a 3". Since your LO3 is pretty low on power the power difference between the two isn't that noticable yet. When you add a cam you will want to go at least 3".
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
I kind of figured that, but wanted to make sure. I am not going to be able to replace the whole thing right away, but if I can run the 2055's with what Ive got for now, then Ill swap the rest later. Ive read a bunch of posts over the few years Ive been on this forum and most pointed to 3", but IIRC most were also either more built up or 350's. I guess 3" is a good future investment for the possibility of either head work, aftermarket heads, or a 350 swap.
I guess now it comes down to buying either a 3" catback for now or the 2055's. I can't get both this year.
Car: '90 RS
Engine: 377 LSX
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Shot you a PM back devestator.
And MKnight.. any V8 ever made would be much happier with a 3" exhaust.
ambainb
Apr 25, 2016 09:21 PM
