What Exactly Should I get Welded??
Old Mar 19, 2006 | 05:31 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
OK, unfortuantely im probably gonna end up taking my car to a shop to have my exhaust put on. My dad doesn't really feel up to doing it, and I want to have it put on soon so i'm probably just gonna take it somewhere. I'm gonna assume they would weld it...however i know the hooker kit comes with everything to clamp it together. I really dont have any plans to change the catback after its installed, so would i want to have it all welded up, or only certain sections?
Old Mar 19, 2006 | 06:18 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
I personally would'nt weld anything. Once really tight it will stay that way.
Old Mar 19, 2006 | 06:19 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I would weld it, leaks are my worst enemy I dont know about urs
Old Mar 27, 2006 | 11:29 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Look at all those clamps, after I installed it, they all leaked. So I had my buddy weld them up. Looks much better and no leaks = way better sound. I even had a leak from the high flow cat to the y pipe, so he welded that up to. So much better.
Attached Thumbnails What Exactly Should I get Welded??-exhaust.jpg   What Exactly Should I get Welded??-excutout.jpg
Old Mar 27, 2006 | 11:37 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
A one piece exhausted (i.e. when welded) must be a paint to install/remove.
Old Mar 27, 2006 | 11:42 PM
krisb410's Avatar
Yes it is, the previous owner of my car had welded everthing behind the cat! I just removed it when I did my rear end swap. But if you didn't want to drop your rear, then cutting it off would be the easy way.
Old Mar 28, 2006 | 02:03 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Weld everything. Clamps are just headaches. Even if you wanted to change the exhaust later you still can. Just get a sawzall or have a shop do it.
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
