y pipe question
Old Mar 21, 2006 | 12:21 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
y pipe question
I was wondering if it would be possible to just use the y pipe off a late model camaro for long tube headers? i was wanting to use hedman long tubes but would like to know this first.
Old Mar 22, 2006 | 10:23 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
you'll need to have a custom one made. You may be able to hack up a LS1 ypipe to get it to work, but I suspect it would be as much work as just starting from scratch.
Old Mar 22, 2006 | 10:30 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
LS1 Ypipe will not work, it's a true Y design and goes straight down the middle next to the driveshaft.
You might have some success with 93-95 Y-pipes, they're the closest to your setup. But I'd recommend just getting a custom one off done.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
hectre13
Sep 8, 2015 03:38 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
