cleaning EGR passages
Old Mar 28, 2006 | 12:55 PM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
Would somebody please put up a pic or diagram on where or how the EGR passages are routed. I failed the Nox part of the sniffer and I want to cover all my bases before I take it to get tested again.
I have installed new plugs, EGR, O2, dual cats, PCV and cleaned the air filter(K&N). I don't want to miss anything. I want to get this over and done with.
Old Mar 28, 2006 | 05:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Not sure exactly how its routed through the manifold, but for what its worth, carb cleaner spray or diesel fuel works well for cleaning that stuff up.
Old Mar 28, 2006 | 05:50 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If you havent... Change your oil also !!!!
Old Mar 29, 2006 | 08:08 AM
hitman's Avatar
okay
Thanks for the tips, but I have another question. I know there is a passage right behind the throttle body, but where does it exit, or where else should I spray?
Old Mar 30, 2006 | 11:21 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Try the passages on the runners if your still running TPI.
Old Mar 30, 2006 | 01:04 PM
hitman's Avatar
yup
still runnin TPI. The runners (big tubes) should be cleaned, or the smaller single tube should be cleaned? Or all of them?
Old Mar 30, 2006 | 02:20 PM
B Rhodes's Avatar
Car: 91 B4C
Sometimes you have to take the EGR valve off and spray it and run a small welding rod or coathanger back and forth to clear the passage in the intake. the valve can work fine but if the passage is carboned up obviously you lose EGR which is what usually causes high NOx readings.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Jsapp38
Nov 13, 2015 07:38 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
