My Magnaflow 3''
Old May 10, 2006 | 11:40 PM
  #51
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I've got long tubes, no cats and a magnaflow. I'll try to get a sound clip ASAP.
Basically it sounds like your grandpa's old '69 camaro with a hi-po 350 in it A.K.A. BADASS!
Old May 11, 2006 | 09:36 AM
  #52
GTA350VORTEC's Avatar
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
Can anyone post better pics of how they hung the interemediate pipe, and tail pipes??
Old May 18, 2006 | 08:17 AM
  #53
Axle/Gears: 3:73
PS. did anyone ever find out if the intermediate pipe was needed to be modified as far as the hanger in order to fit well on thirdgens?
Old May 23, 2006 | 02:45 PM
  #54
Axle/Gears: 3:73
Help! Pics please
Old May 24, 2006 | 12:38 PM
  #55
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
TTT!
Old May 24, 2006 | 02:30 PM
  #56
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I will be installing mine next week (First week of June - I hope).
If no one has any good pics up by then I will post a few.
I will also see about getting a sound clip.
Spec's...
383, 2055's and no cat.
Old May 25, 2006 | 11:50 AM
  #57
Blackhawk355's Avatar
Car: 1989 Firebird
Engine: N2O 355CID
i really would like to hear this cat back system before i go spend 800 on a boomtube or a GMMG cat back, if i can save an extra 400 on my car i will be absolutely thrilled.
Old May 26, 2006 | 05:25 AM
  #58
Axle/Gears: 3:73
Can anyone tell me how they modded their intermediate pipe hanger? The tail pipes I can hang with 360 swingers, but I'm not sure about the intermediate pipe. Thanks
Old May 28, 2006 | 01:24 PM
  #59
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Ive been thinking about getting a magna flow catback for my car. only thing is my catback right now is 2.5, so that means ill need a new cat right?
Old May 29, 2006 | 06:32 PM
  #60
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Tripple T!
Old May 29, 2006 | 07:26 PM
  #61
Car: '72 Chevy Nova
Transmission: TH350
I put a clip of my magnaflow setup on these forums, it's down a few posts
https://www.thirdgen.org/forums/exha...ust-clips.html
Old May 29, 2006 | 08:43 PM
  #62
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
i'm getting a magnaflow cat back for 45 bucks..... used for about 10,000 miles... can't wait... i'll post some sound clips....
Old Jun 1, 2006 | 05:36 PM
  #63
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
How do you guys think this exhaust would sound on my carbed 400 small block (Mild port work to chevy casting 882 heads and an edelbrock cam)? I'm running hooker shortys and hooker y pipe.
Old Jun 1, 2006 | 05:38 PM
  #64
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
speaking from experience it would sound really badass
Old Jun 2, 2006 | 09:20 AM
  #65
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
So which one fits better??? the one for the LT1 or the LS1??? Is there any major difference or advantage between the two systems? Im only asking because Im putting this on my LS1 swap TA.... So if the flow of the LS1 system is set up to maximize sound and power for the LS1...Ide probably lean towards that system. Magnaflow's site doesnt really get into the difference. The pictures dont really show too much difference.
Both are 3" in and 2.5" out... Anyone know what the difference is??
Justin
Old Jun 2, 2006 | 04:55 PM
  #66
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
The LT1 setup looks like a crossflow muffler, whereas the LS1 setup looks like a straight through flow muffler like the SLP 2otl muffler.
Old Jun 3, 2006 | 11:36 PM
  #67
Engine: 400
Will the Magnaflow system be louder than a Hooker Super Comp. Catback?
Old Jun 4, 2006 | 08:36 PM
  #68
yes it will and alot less interior noise too
Old Jun 4, 2006 | 10:31 PM
  #69
Engine: 400
I'm getting it for sure then. I WILL POST SOME SOUND CLIPS!
Old Jun 4, 2006 | 11:02 PM
  #70
V6sucker's Avatar
Engine: blown up
you need to do a few things.
I am not using that "S" pipe that comes with the kit.
I am buying a 45* bend and some straight tubing. I am also not using a CAT so... but either way you would need a little tubing I bet.
As far as the I pipe hanger itself, I am using one of those hangar L brackets that comes with those universal hangars that use put the tube clamp over.
That will let one bolt (at least) to bolt to the cat hangar bracket.
Old Jun 6, 2006 | 12:56 AM
  #71
Axle/Gears: 3:73
What about the hanger on the pipe that connects the i-pipe to the muffler, the one that goes over the axle. The pipe I got from magnaflow only has a flat brcket on it? How do you think I should mount this pipe? Use a 360 swinger universal hanger and bolt it where the original pipe hanger was, or should I try to fab something that would attach to the orginal rubber hanger thats on the passenger side? This hanger pretty much supports the whole muffler so I want to do it right. Thanks.
PS again pics would be great.
I have attached a picture of the pipe I'm talking about. The end shown furthest away to the right attaches to the i-pipe, the end closest attaches to the muffler.
Old Jun 6, 2006 | 08:11 AM
  #72
Car: '72 Chevy Nova
Transmission: TH350
They're both crossflows. However if I look in one end I can see out the other.. they're very unrestrictive.
Old Jun 9, 2006 | 04:17 PM
  #73
Axle/Gears: 3:73
Well it fianlly stopped raining here in NY so I got a chance to test fit my Magnaflow 15620. After taking a look at some Walker diagrams for the 4th gen, I realized that you can uses Walker part no. 36398 to mount the over the axle pipe to the stock location on your camaro/firebird. The bracket costs 9.00 and will probably have to be special ordered. I just thought that this might help some people out.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
