hooker 2055, installed, but how to tighten spark plug?
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
The #4 spark plug could not be properly tightened with my long 5/9" socket that i used for the other plugs because the header pipe is in the way...is there some "special" socket/tool that will fit over the plug and clear the header pipe?
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ITs a SOB I think i remember taking the rubber **** out of the socket slipping it over, it just barley fit. i cant remember if it was with or with out the wrench. some of them i had to put the plug socket on then use a wrench to tighten it.
Car: 2018 Corvette Grand Sport Z07
Transmission: C7 Z06 TR6070
I had a similar problem with my flowtech headers. I use a 1" offset box wrench with the one end cut off so it doesn't get in the way. I only use the wrench, no spark plug socket.
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
1/2" drive spark plug socket cut down really short. Use a box end wrench to tighten the spark plug.
Car: 1985 Camaro
Engine: 350 .030 over (355)
What I use Member
Car: 88 IROC
Engine: 305 tpi
Transmission: 5 speed
1 3/8" drive spark plug socket
1 hacksaw
1 19mm offset wrench
Now remove the rubber from the socket. Cut the socket down in size so that it fits. Here is a trick most spark plugs (I use bosche supers) can have the tip (plug wire goes on) removed, it simply unscrews and screws back on, it will save you room to put the shortened socket on. Then tighten or loosen the spark plug as needed using the offset wrench instead of a ratchet.
Like what the guy above said.
1 hacksaw
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
