Smog Removal Question
Old May 3, 2006 | 07:04 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I got one quick question about removing the AIR system. I going to be taking it off of my LG4. I dont have the serpentine belt setup, and I looked at the AIR pump and it appears that the belt isnted connecting to anything else. I can just remove the whole assembly and not need the AIR delete pully, correct? Thanks
Old May 3, 2006 | 07:38 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Of course you can. Don't worry about the air pump delete pulley, it's only necessary on serp belt setups.
Old May 4, 2006 | 12:11 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Thank You!
Old May 4, 2006 | 11:27 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
No it isnt
Old May 4, 2006 | 12:01 PM
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
Originally Posted by scooter
No it isnt
care to explain?
Old May 4, 2006 | 12:04 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
If you have the serp setup you can just remove the pump. You dont have to put the replacement idler pulley in there. It has been discussed several times. I think the only thing you should do is get a shorter belt. I just rerouted the belt and it is a little too long and the tensioner is at one of its limits. I am going to be running a new water outlet soon and will probably need to replace the belt because of it so I havent bothered buying a new belt. I dont have any problems though with belt slippage either
It is in a tech article
https://www.thirdgen.org/serpentine
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
