My Decision on Headers Back
Old May 11, 2006 | 02:07 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
I have decided to go with a system that alternates between 2.5 and 3inches based on my cousin (the exhaust mechanic and 450hp stang owners) advice. I'm going with hooker 2460 which is 1-5/8 primarys to a 3" collecter to a 3" in 2.5" out hooker Y. 2.5" intermediate pipe and a 2.5" in to 3" out custom over the axel pipe. All this to a classic series 40 3" in dual 2.5 out. I'll use dumps to solve my problem of the change in muffler outlet locations. I think its gonna sound bitchin, add full flow and just enough backpressure for my engine with the 2.5 intermediate pipe. What do you think?
http://store.summitracing.com/partdetail.asp?autofilter=1∂=FLO%2D430402&N=4294923429+4294922711+4294922710+400238+4294906131+4294791974+4294791977+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1∂=HOK%2D16767HKR&N=4294908216+4294908198+4294925005+4294923429+4294856041+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1∂=HOK%2D2460HKR&N=4294908216+4294908198+4294925005+4294923429+4294918680+115&autoview=sku
Old May 11, 2006 | 02:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why go to 2 1/2" instead of keeping it 3" all the way back?
Old May 11, 2006 | 02:39 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Ya just go 3" all the way, the whole urban legend about not enough backpressure is false.
Old May 11, 2006 | 03:09 PM
r0nin89's Avatar
Well then I'm gonna have to make a 3" intermediate pipe when i get the money and time. Until then I'm going with that setup. I can always cut the y pipe before it tapers and change my over the axel inlet to 3inch with one cut and one weld.
Old May 11, 2006 | 03:20 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
yesa dont go down to 2.5" it will just choke your motor. dual 2.5" is cool but single 2.5" is baaad
Old May 11, 2006 | 05:13 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
This will work, but you will want to switch to a 3" pipe for sure later on. Backpressure is what you don't want!
You have to consider where your car is going to be running RPM wise. Sounds like this is a street car. With those 1 5/8" primaries on the shorties you're already set for an RPM band where the street is in mind. If you run 2.5" pipes you're going to choke down the motor too the point where it isn't tuned length exhaust anymore - it's just a restriction.
Old May 11, 2006 | 05:31 PM
r0nin89's Avatar
Alright well thanks for your help guys! Anyone know if those dynomax intermediate pipes for our cars (3in) will bolt up to the hooker Ypipe?
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
BlackTopKing
Aug 19, 2015 12:13 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
