To much flow?
Old May 12, 2006 | 01:51 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
To much flow?
I just installed edelbrock shorties and glass packs on a 2.5" mandrel bent exhaust that exits out the side. the ypipe goes back more then 3/4 of the exhaust through duel glass packs before joining to one pipe and exiting.
after installing, the car wont move barely. revs fine, and idles fine but when i put it in gear (manual trans) and give it gas it just want to die and sputter!
to much flow, not enough back pressure?
here is a my exhaust:
Old May 12, 2006 | 03:22 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
To much flow is not your problem. You don't want back pressure. You have something else wrong. If indeed your exhaust is free flowing look elsewhere for the problem.
Old May 12, 2006 | 03:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
https://www.thirdgen.org/forums/exha...-you-ever.html
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
84redta
Sep 19, 2015 09:58 AM
