Duals before axle, clearance?
Old May 28, 2006 | 10:15 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Anyone managed to tuck them nice and tight without using oval tubing? I just don't want it all visible from the side. I think if you can see the pipes from the side of the car I should grow a mu11et. I plan on using a pair of heddman longtubes and Edelbrock mufflers with turndowns.
Old May 29, 2006 | 12:23 AM
klumb15's Avatar
mine are as tucked up as your gonna get them...the lowest point is obviously under the crossmember, there is no way around that...but this winter I migth make a custom crossmember, that kind of looks like the aftermarket one made for long tubes so then i can cut that chunk out and it won't be visible from the side at all..
Old May 29, 2006 | 08:35 AM
Dialed_In's Avatar
Bad thing is I've got the Spohn TH400 torque arm
91 SrS
Oct 7, 2015 04:32 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
zman1969
Oct 1, 2015 11:09 AM
