LT pipes
Old May 29, 2006 | 08:17 PM
racnboy87's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
LT pipes
I have a 92 RS LO3 with a 5 speed. Are there any long pipes that will fit on my car with no modifications?
Old May 29, 2006 | 09:06 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
If what you are indicating by long pipes, long tube headers, then yes they can be had through summit for 135 and are made by heddman.
Old May 30, 2006 | 09:47 AM
racnboy87's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
yes i am talking about long tube headers. so heddman's will fit with no modifications, and i wont have problems with ground clearance?
Old May 30, 2006 | 10:35 AM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Yup I have them in mine, I had to take a grinder to my A-arm perch a little just to clearance it but other than that they fit PERFECT! and as long at you take the starter, knock sensor, and oil filter out they are easier to take in and out from under the car that it was to put shorties in from the top side. and to give you an idea of were they sit, mine are about a half inch if that lower than the oil pan.
Old May 30, 2006 | 04:55 PM
racnboy87's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
would you reccomend them over hooker shorties. i was thinkin about gettin the 2055's since they will fit with no modifications and come with a y pipe.
Old May 30, 2006 | 08:16 PM
Car: 91 Z28
Engine: Lt1
for your application absolutely. long tubes really only help you out if your building a 400+ hp setup and even then its only a marginal increase. I went long tubes since I wanted the cool factor and duals, also I NEVER wanted to have to upgrade my exhaust again no matter what I did to the engine.
Old May 30, 2006 | 09:07 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
nope.. hedman wont fit with t-5.... the collector come out right where the slave cylinder is... hookers will fit but u need a mini/lt1 starter....
Old May 30, 2006 | 09:18 PM
Car: 91 Z28
Engine: Lt1
umm are you sure cause I have a T56 snd thats ALOT wider than the T5 and it cleared the tranny with room to spare
Old May 30, 2006 | 09:58 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
well im not 100% sure because ive never done it but ive read places on how to modify those to fit soo im pretty sure... a t56 also has a different style clutch that might have the slave cylinder in a little different position...
Old May 31, 2006 | 05:46 AM
Car: 91 Z28
Engine: Lt1
I also heard conflicting stories/rumors that the hedmans dont fit with T5/T56s so I was prepared to have to do a little clearencing when I got mine (68469 Dport) but I was pleasently suprised like I said earlier, only had to clearence the A-arm. Im pretty sure a T56 slave setup is pushed out farther toward the headers than the T5 and I know there is a couple of guys on here that have T5s and the hedmans so it is possible and for the price (135) they are hard to pass up you can even get the coated ones for 350 last I checked.
Old May 31, 2006 | 07:47 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
IMO Heddman makes a very cheaply designed product. I'd go with the Hooker long tubes.
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
