Cat Hanger Fix & P#'s
Old Jun 13, 2006 | 03:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Though GM has discontinued the cat hanger (and though you could probably locate something in the bone yards), the fix, at least for my T5, was simple--and I thank phess11 for putting me on the right track--Napa 35245 and/or CarQuest 529077. Both are about $14. My CarQuest kit came with three bolts and nuts.
1) remove the old hanger from cat and tranny
2) drill out the rivet to separate the rubber from the metal piece that bolts to the transmission
3) attach the kit to the tranny piece and bolt it in place. If you use a bolt from the kit, you'll need to make the hole in the tranny piece a bit larger (This bolt goes through the rubber and tranny piece to fasten the two together just as the rivet did. I used a washer the same size as the original rivet head above the rubber).
4) bolt up to tranny and cat
JamesC
Attached Thumbnails Cat Hanger Fix & P#'s-hanger1.jpg   Cat Hanger Fix & P#'s-hanger3.jpg
Old Jun 22, 2006 | 12:13 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I returned one of those the other day because I thought it was the wrong piece! Thanks for the info.
Old Jun 22, 2006 | 12:54 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
There's a kit? Who knew....
I just did the same repair for my car, but I used a piece of an old motorcycle tire and some nuts & bolts from ACE Hardware. It worked well.
Old Jul 17, 2006 | 09:12 AM
JB22's Avatar
beautiful!
just what I was looking for
James, your the man with the answers to all my Q's lately
Old Jul 18, 2006 | 08:51 AM
JB22's Avatar
James,
What size bolt did you use to replace the rivet?
I wanna stop and get the parts I need before the weekend so I can do this this weekend.
Thanks in advance
Old Jul 18, 2006 | 09:41 AM
JamesC's Avatar
I just used one of the bolts that came with my CarQuest kit.
JamesC
Old Jan 15, 2008 | 04:26 PM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Re: Cat Hanger Fix & P#'s
Does this part fit the dual cat cars also?
Old Jan 15, 2008 | 04:40 PM
JamesC's Avatar
I'm unfamiliar with dual cats, but from pictures my guess is that the part is the same.
JamesC
Old Jan 20, 2008 | 10:25 AM
Engine: L98 5.7
JamesC,
Thanks for the response, I appreciate it! I found this pic on the internet and it shows the dual cat backet. It looks like this one bolts to the trans and yours attaches to the crossmember. I wonder if I could use the one you show anyways.............looks like it might work.
Old Jan 20, 2008 | 01:00 PM
JamesC's Avatar
Mine attaches to the tail shaft of the trans as well (note the directions above). With the exception of the piece that connects the hanger with the pipe/cat, the two look similar. If you're merely looking for the rubber piece (and already have the rest), you might be in business.
JamesC
Old Jan 24, 2008 | 11:27 AM
Engine: L98 5.7
JamesC,
Thanks again for the input, I appreciate it. The car comes home next week from the paint shop so I'll check out what I really have. Hopefully I just need the rubber piece. I was just trying to be proactive and get a couple things done ahead of time.
Old Jan 24, 2008 | 11:33 AM
JamesC's Avatar
Never works for me either
JamesC
Old Jan 25, 2008 | 12:15 PM
Engine: L98 5.7
JamesC,
I hear that........you seem like you provide alot of input on this board.......here's a question I posted recently and haven't been able to get feedback on..........any help is appreciated!
Hello all,
I'm about to install a VPA keyless entry system. I have looked at the tech guide and searched posts but I still have a question on how this is done.
It says in another post I saw here that you cut and use the white and light blue wires in the harness...........when I look at the guide, it says there are three wires, light blue (lock), black (unlock) and white (trigger). Do I do anything with the black wire?
Just want to make sure before I cut anything!
Old Jan 26, 2008 | 05:23 AM
JamesC's Avatar
Sorry, no experience with that system.
JamesC
Old Jan 28, 2008 | 08:15 PM
Engine: L98 5.7
JamesC
Thanks anyway, it was worth a shot!
Old Feb 11, 2008 | 07:06 PM
Engine: L98 5.7
JamesC,
I got the car back and figured this out..........I didn't realize the small metal piece actually ties to the trans bracket..........makes it alot easier when you are actually looking at it.
I have the tranny bracket, but the rest is gone. I bought a used bracket off of ebay for like 20 bucks so I should be good now!
Thanks again for the help!
Old Feb 8, 2009 | 06:49 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Yes i know, its old. But do any of you have a pic of the cat AND bracket on a single cat car? my bracket has a piece welded to it, then that is welded to the pipe behind the cat. Just want to know how this mounts to the pipe. Thanks
Old Feb 9, 2009 | 10:02 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
TTT
Old Feb 11, 2009 | 02:19 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
James, what size cat do you have? My stock cat was a smaller single cat for a 305TPI, I have upgraded to an OE 3" Magnaflow cat and noticed the cat side metal piece won't interchange, the bolt pattern is different on the cat bracket/flange due to the larger pipe diameter... I was hoping this worked for you with the 3" cat to save me some fabricating.
Old Feb 11, 2009 | 03:13 PM
JamesC's Avatar
Originally Posted by zride91
JI was hoping this worked for you with the 3" cat to save me some fabricating.
Three inch all the way.
JamesC
Old Feb 11, 2009 | 04:32 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
That is a beautiful thing, THANK you very much!!
Old Jun 11, 2013 | 07:24 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
JamesC, out of curiosity, do you have a 4 bolt cat on your car? The cat side bracket appears to be a 4 bolt style. It's definitely different from the 2 bolt bracket I have.
The NAPA piece does not appear that it would work on my cat, however the rubber part would work.
Old Jun 11, 2013 | 07:35 AM
JamesC's Avatar
The bracket itself is the one that was original to the car. I used it both on the LG4 and the L69 (four-bolt cat) that I converted the exhaust to.
The Napa and CarQuest part numbers are for replacement rubber only.
EDIT: I'm currently using the piece on a Hooker, Catco, Hooker system. No issues.
JamesC
Old Jun 11, 2013 | 11:47 AM
82tarecaro's Avatar
I bought this hanger for my car. I originally had the 2 bolt cat. I converted the exhaust to L69 specs with a 4 bolt cat, magnaflow y pipe and Dynomax cat back. This will work with the 4 bolt cat, but you need to drill another hole in it as one of the holes in it does not line up with the 4 bolt flange. No biggie - and it is a sturdy piece.
Old Sep 26, 2015 | 03:36 PM
Winchester1094's Avatar
Came across this post while looking for a fix for the notorious cat hanger failure. CarQuest number got me nothing but I ran the Napa number through RockAuto and found it for $9 just in case someone is looking. http://www.rockauto.com/catalog/more...&jnid=4&jpid=2
Old Sep 26, 2015 | 04:06 PM
JamesC's Avatar
Many thanks for the additional info.
JamesC
Old May 10, 2016 | 10:12 PM
formula00ra's Avatar
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
I used the original auto hanger. Got a piece of aluminum at Home Depot about an inch and a half wide. Marked the tail shaft bracket holes on it then marked the auto bracket hole on it. Drilled all 3 holes and attached it to the tail shaft and attached the one auto trans bracket to the aluminum. Then I just used spacers and longer bolts to hook up the converters to the other end.
Old May 18, 2018 | 09:44 AM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
Is this the correct part for going from 700R4 to T5 in a single cat vehicle? I just noticed that the holes in the piece that connects to the rear of the 700R4 are not the same distance apart as the two holes on the T5 . I was hoping for an easy (good fitting) solution.
Old May 18, 2018 | 02:39 PM
Drew's Avatar
No, this part is the rubber and cat side of the mount only.
Old May 19, 2018 | 06:26 AM
Engine: 350 ci
I used the original auto hanger for my T 5 conversion. I just added a couple of thick washers ,that I got out of the Wilmington plant where I worked years ago, and longer bolts to connect to the cat's. works fine.
Old Jan 15, 2020 | 10:38 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Back from the dead......again
Amazon Amazon
is telling me this won't work with my 91 Firebird, can anyone confirm that it will work with a 700R4?
Old Jan 15, 2020 | 11:37 AM
Drew's Avatar
Amazon is telling me this won't work with my 91 Firebird, can anyone confirm that it will work with a 700R4?
Well, it's the end that bolts to the cat, so it really shouldn't matter. They expect you to reuse the end that bolts to the trans, which is different for T5 or 700R4. The cat end is potentially different for single vs dual cats, and some cats might have a different bolt spacing. You can pull up the measurements in the PDF on the Walker website to find out if it'll bolt to your flange.
Old Jan 15, 2020 | 12:22 PM
91banditt2's Avatar
Engine: 5.7 HSR
maybe it’s just me but I’m not having any luck navigating their site, I’ll try again but from a PC
Old Jan 15, 2020 | 12:25 PM
Drew's Avatar
Just happen to have a screenshot from a few weeks ago...
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It's for a single cat car but it won't replace the transmission side of the bracket. Won't fit dual cat cars without mods
Old Jan 15, 2020 | 12:27 PM
91banditt2's Avatar
Engine: 5.7 HSR
Old Jan 15, 2020 | 12:36 PM
Drew's Avatar
I need to dig out my various hangers one of these days and do a side by side comparison. I know the Walker hanger says it doesn't fit some of the single cat applications, and I know the auto vs 5spd hangers are different because the torque arm brackets are different, and the N10 is different. Figure there are more varieties out there than a person would expect, who knows exactly which the Walker was designed to replace.
Old Jan 15, 2020 | 12:47 PM
TTOP350's Avatar
In my eyes, it's pretty much a replacement for the rubber that rots away..
Old Jan 15, 2020 | 12:56 PM
Drew's Avatar
Agreed. Also would come in handy for those times a previous owner threw out the cat and welded the cat end of the bracket to their 'test pipe', or when they've cut the rubber and thrown the cat half of the bracket in the trash with the cat.
Old Feb 18, 2020 | 05:20 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Anybody need any of these?
Old Feb 18, 2020 | 05:38 PM
TTOP350's Avatar
I may be interested in the one on top left of pic.
Old Feb 19, 2020 | 05:30 PM
  #42
Dyno Don's Avatar
The second picture?
Old Feb 19, 2020 | 05:56 PM
  #43
TTOP350's Avatar
Originally Posted by Dyno Don
The second picture?
Yup. PM me if you would, thanks
Old Mar 10, 2020 | 08:23 PM
  #44
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Dyno Dan. Either one of those designed for the T5 with dual cats?
I need one Asap.
Old May 10, 2020 | 11:54 PM
  #45
DontBlnkBadWolf's Avatar
Car: 2002 Dodge Ram 1500 Quad Cab
Engine: 4.7 Liter
Transmission: 4 Speed Auto
Prices can change in 14 years since this thread was started. It's no longer $14 but, over $16 now (That's depending on your location). I just decided to link the Napa part here for others. https://www.napaonline.com/en/p/EXT35245
akmusclecar
Jun 24, 2009 06:24 PM
doc
Oct 13, 2008 10:37 PM
eddie jr
Jul 29, 2003 09:14 PM
Flash84Z28
Feb 19, 2002 03:36 PM
