should i get my cat taken off? CALI
Car: 85 T/A
Engine: l98 ,cam,exhaust
Transmission: beefed up 700R4
Axle/Gears: 2000 ss 3.42s
i have 89 l98 vette engine in my 85 T/A with zz4 cam 1.5 rockers,shorty headers,aluminum heads, all stock piping into a 80 series muffler, im going to change my whole exhaust in about a month and i'm getting a new cat as well, my question is in the mean time i need to weld my Y pipe up to the existing exhaust will taking off the cat draw to much unwanted attention with my mods, or should i just have the Y pipe welded up to the cat or taken off? my car sticks out like white on black so im not sure, non of my smog or air pollution is hooked up as well!
you only live once, i think if you already know what you want, then thats what you should do, as long as bush sent people to iraq to make him and his friends more money, you can anything to your third gen as you like
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
First, please keep your political views to other websites.
Second, you arent going to pass CA emissions without a cat on there, so you must have one for the test. What you do during the rest of the two years between tests is your business. However, removing your catalytic converter on a street car is a federal offense, punishable by a fine, jail time, and/or both. Especially in this tree-hugging state of CA.
My ET and horsepower numbers are thru dual 2.5" Magnaflow cats, so if I can make this much power and be smog legal, so can you.
LT1Formula
Oct 8, 2015 08:34 PM
