a couple of questions
Subscribe
Jul 9, 2006 | 05:17 PM
i'm swapping in a scoggin-dickey vortec tpi crate motor
i want to get headers for it
1.what would be the best headers?, i've read longtubes will scrape on a lowered car(which i have)
2. will i have to get a new y-pipe or will shorties bolt up to my stock one?
3. i want ceramic coated ones
thanks
Reply 0
Jul 9, 2006 | 05:40 PM
The sticky at the top should answer your questions
Reply 0
Jul 9, 2006 | 06:19 PM
it doesn't answer whether they will fit my vortec heads or not
Reply 0
Jul 9, 2006 | 06:30 PM
Hooker 2055's fit my 350 HO Deluxe which has Vortec heads. The Y-pipe is the best available, IMO; however, it sits a bit low (search for more info). Why consider headers in the first place if you're going to restrict flow with a stock Y-pipe (which would never bolt up anyway). Do it right the first time.
JamesC
Reply 0
Jul 9, 2006 | 06:35 PM
my cat is welded to my stock y-pipe, how would the exhaust shop connect the new y-pipe to the cat?
Reply 0
Jul 9, 2006 | 06:38 PM
You could go with a Catco 9118 which is a direct fit (along with a Hooker catback should you be willing to spend the bucks). At any rate, any self-respecting muffler shop should be able to fix you up.
JamesC
Reply 0
Jul 9, 2006 | 07:55 PM
Quote: my cat is welded to my stock y-pipe, how would the exhaust shop connect the new y-pipe to the cat?
They'll cut it off the old one and weld it to the new one.
Reply 0
Jul 9, 2006 | 07:56 PM
another question, would the hooker 2055s bolt up to my stock y-pipe?
edit: Hooker Super Competition Headers: HOK-2055-1HKR - summitracing.com
745 dollars? thats alot
Reply 0
Jul 9, 2006 | 08:11 PM
Quote: another question, would the hooker 2055s bolt up to my stock y-pipe?
To my knowledge, no set of aftermarket hearders will bolt to the stock Y-pipe. Again, why bother? The stock Y-pipe's restriction would make the headers next to worthless. Try Jeg's p/n 520-2055.
JamesC
Reply 0
Jul 9, 2006 | 08:46 PM
does that come with a y-pipe? and are those ceramic coated?
Reply 0
Jul 10, 2006 | 05:13 AM
Comes with the Y-pipe. That price doesn't include coating.
JamesC
Reply 0
Subscribe
