Does this sound right?
Old Jul 15, 2006 | 09:36 AM
Sneaky Neil's Avatar
Ok, I will be getting full exhaust for my 90' Formula TBI so here is the plan:
After reading a bunch on the forum I think I will go with
1. Hooker 2055 headers with y-pipe
2. Catco 9118 converter
3. Hooker 16823 catback
Will all of the this work together and bolt up without welding or other modifications? I need everything to be emmissions legal too. Do I need anything else to install this? Thanks a lot.
Neil
Old Jul 15, 2006 | 10:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes.
No.
JamesC
It's good.
JamesC
Old Jul 15, 2006 | 01:12 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Old Jul 15, 2006 | 01:22 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
You're probably going to need all 90* spark plug wires. The stock plug wires have some straight ends that usually hit the tubes when you install headers. You can get aftermarket plug wires from companies like MSD, Accell, etc. or you can just get stock replacement plug wires for a late-model GM truck (for example, an 89 Chevy 1500 with a 350/5.7 motor). Those trucks came stock with 90* plug wire ends.
Old Jul 17, 2006 | 07:52 AM
Cool. Thanks. I will have to check on those plug wires. I may use some from my '95 Z. Is it common to burn plug wires with these headers?
Old Jul 17, 2006 | 08:01 AM
JamesC's Avatar
I run mine underneath the 2055's and managed to burn one wire immediately after install, but that was my own fault. Nothing since.
JamesC
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
