Transfering Headers and Exhaust off a '92 Camaro to an '88 Firebird.
Old Jul 19, 2006 | 02:08 PM
camaro_thirdgen's Avatar
Car: Pontiac Firebird Trans AM, GTA
Axle/Gears: Borg Warner
Will I run into any problems transfering Headers and exaust from my '92 Camaro to my '88 Firebird TransAm? The Camaro is a 305 Throttle Body Injection, the FireBird has a 350 TPI, and the headers are not emissions legal but im not worried about it not passing an emissions test.
Will the car have any problems with the emissions besides passing the smog test, and if it might...what can I do to prevent or fix it???
Old Jul 19, 2006 | 02:56 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
They are the same body style (f-body), engine dimensions, etc., so I don't see why not.
Old Jul 19, 2006 | 03:33 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
The only way you would have problems is if it has longtubes and the camaro is an auto and firebird is a manual. Also if it is all welded you will have to cut the muffiler off to remove all the exaust. Unless you removed both rearends from the cars so you could keep it all intact. To much work to do that to me tho.
Old Jul 19, 2006 | 03:58 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
One thing you may run into is clearance on the firbird....age of motor mounts etc......also every car has its variations........it should be pretty straight fwd.....as far as emissions in Cali........find "the place to get emisions inspections done"......find that Millitary hook up........if you have a visual inspection you could attach "dummy" air tubes........
good luck,
Mike
Old Jul 19, 2006 | 04:15 PM
Thank you...So...
So I shouldn't run into any problems with the computer then?! They are both auto.
Old Jul 19, 2006 | 04:18 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
You may need to install the O2 into the new headers......
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
