Hooker Shorty Installation Question
Old Jul 22, 2006 | 08:29 PM
bbq014's Avatar
Car: '88 IROC
Axle/Gears: 9", Locker, 4.10's
Hey guys,
it says that the headers need to be installed by jacking up one side of the motor to slide one in...
but i was wondering, since i'll be removing my AC And AIR system and getting that crap out of the way before i put these headers in, would i still have to do that or can i work them in there without having to jack the engine up.
if anyone knows for sure please let me know... wanna get this done in the next couple of days... thanks!
ps. already got the AC out need to remove the smog system and switch out the smog headers for the non smog headers
Old Jul 22, 2006 | 08:36 PM
kjvail1204's Avatar
I had a set and if i remember i didnt have to jack up anything, Just undo some sterring components
Old Jul 22, 2006 | 08:40 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
driver side unbolt the steering shaft and maybe take plugs out...passenger side take back plugs out and theres a sensor there maybe that needs to be taken out and work it in from the bottom use a rubber malet if u need to
Old Jul 22, 2006 | 08:54 PM
morbital's Avatar
Car: '89 Camaro RS
Engine: 5.7 LS1
Transmission: 6 SPD.
Axle/Gears: 3.25
i installed my shorties, the driver side can be installed withouth going underneath the car, but of course you had to undo the steering column mechanism that goes to the pump .. which is a bolt away.. for the required space..... the passenger side had to be installed at the bottom of the car, because of the firewall got in the way. and if you used hedman ... like me.. you had to either pull down the header, which of course you can only bend the pipes 1/2 an inch. so it wont meet up your heater pipe.. of course you had to move the header at certain angles to get it positioned to the motor.. dont force it to much or you have to replace your valve cover, but hey if you can find a better way to install the passenger side without going under the car i would like to know!!!
Old Jul 22, 2006 | 09:50 PM
bbq014's Avatar
Car: '88 IROC
cool so the pass side should be my major problem then... cause i have ceramics and i don't want those babies to get scratched ... did you mean i had to feed it up from the bottom or pull down from the top with them?
Old Jul 22, 2006 | 10:02 PM
gray89vert's Avatar
Engine: 305 TBI LO3
u have to put them in from the bottom. good luck not scratching em
Old Jul 23, 2006 | 02:10 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
You don not have to install the hooker shorties from under the car....nor do you have to unbolt the steering shaft.You do need to remove all of your plugs,as well as the temp sens. for the fans.They will go in from the top with no problems.
Good luck,
Mike
Old Jul 23, 2006 | 04:45 PM
bbq014's Avatar
Car: '88 IROC
cool thanks mike... i'm trustin ya on this hope your right!
headers are in the mail....:-D
Old Jul 24, 2006 | 06:49 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
I just removed a set of 2460's from my car to install my Headman longtubes.....It took me a total of about 30 min. to remove the 2460's....I didn't have a y pipe on it........my car had AC so all that crap was still in the way(only thing removed was the compresor and lines).It may help to put your car up on ramps/ jackstands so you don't have to bend so far over.Once you get the old manifolds off....(start spraying them down now with some kind of penetrating oil) and the stock y pipe out of the way you will have plenty of room to install the hooker shorties.
Good luck,
Mike
Old Jul 24, 2006 | 08:24 PM
unklechuckles19's Avatar
Car: 1987 Z-28
Engine: 355
Axle/Gears: 10 Bolt/3.23 peg leg :(
84ZMIKE, you didnt have any problems going in from the top on either side? I've got a set of Hedmans that I'm putting in this week, and I was gonna go up from underneath on the passenger side, and wasnt sure about what to do on the drivers side. Sounds like I'll try unbolting the steering shaft and going in from the top.
Old Jul 24, 2006 | 08:44 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I am really not sure how people have problems with this? I have installed mine from the top with no problems and no scratches... took 30 minutes to put new ones on and torqued. (not counting removal)
Old Jul 25, 2006 | 02:50 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
it was easy as hell to put my 2055's in.I have both my smog and a/c removed though.the only little problem I had was getting the driverside header in. i had to pull back and bend the brake lines a bit to guide it through.
Old Jul 25, 2006 | 05:41 AM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
No problems going in from the top with the 2460's now headmans that I can't say for sure as I havn't done a set of shorty headmans.The only header that comes close to the steering shaft as far as I know is SLP's.If you do go from under the car on the drivers side the best way is to point the header to the rear of the car then as you go under the car rotate it up into the opening and turn the outlet flange towards the passenger side of the car....if that makes sense to you....but installing shorties from the bottom and removing the steering shaft doesn't make much sense to me.
Old Jul 25, 2006 | 06:12 AM
Car: 1987 Z-28
Engine: 355
lol, I've done a couple sets of headers on my buddies cars, so either way I'll figure it out. I've got the car on jack stands now and the old exhaust off, so I'll take my time and get it done. Thanks for the help guys.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
