I pipe
Old Jul 24, 2006 | 06:05 PM
dustpusher's Avatar
Car: 88 IROC-Z
I pipe
I did a search and didnt come up with any ansewers.How high does the car have to be and what needs to be removed?I am going to install a new one tuesday.Thanks for the help.
Old Jul 24, 2006 | 06:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I was able to remove my I-pipe while doing a fuel pump replacement (I took out from the cat back to avoid removing muffler from I-pipe) - but I can't tell you exactly how high as I didn't measure it. I think the jack I used raises 17 inches, as compared to most that only raise 14. I jacked up on the differential, and put the rear on jack stands just in front of where the LCA's connect to the body, as high as I could get it (the nose touched the driveway) - then when you remove the endlinks, shocks, and panhard bar, you can lower the rear way down (watch that brake line on driver side!) and get the I-pipe out - it is a puzzling wiggle though. Of course taking the wheels off increases how far you can lower the rear - just don't bust that brake line.
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
