What sealant withstands the heat?
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I put JB weld on the part of my y-pipe that goes under the oil pan because with the Hedman y-pipe, you clamp it in that spot, and the clamp will not clear my oil pan. Wel;l after running it, I guess the JB weld got so hot that it is now flaking off and leaking once again. What kind of sealant should I use to take care of this, the clamp just will not fit and I need help until I can get it welded. Thanks guys.
Car: '85 Iroc-Z
Engine: 355cu, 11:1, 292H, 750cfm, LT1 head
Transmission: T5 non/wc
Axle/Gears: 3.73, 7.5in 10bolt posi
The best way to go is to weld it, I don't think that cold weld will last there and you don't give you a chance by not installing the U-Bolt!!
You can check on e-bay to get a wider clamp (like SLIP-ON type)that will clear the pan. I personnaly go whit the weld solution but not all the muffler shop want to weld it (no ones want to work!!!
I just regret to have not buy a edelbrock system that bolt-on right a the cat flange and whit the OEM 2 bolt type headers collector
)I just regret to have not buy a edelbrock system that bolt-on right a the cat flange and whit the OEM 2 bolt type headers collector
