Right size pipes on true duals?
Old Jul 27, 2006 | 09:10 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
I am going true duals on my 85 Trans Am.The muffler shop says that they have to run 2" pipes because of clearance.Is 2" to small?It has a carb 350 bored 40 over if that means anything.
Old Jul 27, 2006 | 09:22 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you running manifolds or headers
if manifolds then what diameter outlets ?
no pint in going larger pipe if youre smaller at the front
see
2.25" pipe would be the largest i would run on such an engine
really.
good luck
Old Jul 27, 2006 | 09:23 PM
85T/A350's Avatar
Engine: 350 Vortec
Im running Hooker competition shorties headers
Old Jul 27, 2006 | 10:24 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
and find some pics. print them off and take them to the exhaust shop....I wouldn't waste the time and money going less than 2.5.
Good luck,
Mike
Old Jul 28, 2006 | 01:42 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
I'm by no means an authority here (didn't know anything about V8's 5 years ago) but the answer depends on the rpm's you want to be able to spin it to.
I encounter "the wall" at 3500 with a single 2.165" pipe on my 305, and according to the recommendations in the stickies here I will want to go for 2.5" duals, the biggest that could be considered suitable for a 305 @ 5500.
My calculations predicts that you will hit "the wall" between 5000 and 5500 with 2" duals on a 350, I think it would be slightly restrictive.
Of course everything in an engine depends upon each other and as you see you get just as many opinions.
Just my ..
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
