LT with lakewood bellhousing???
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
is anyone running Lt's with a lakewood bellhousing? i am, however the drivers side header is too close to the slave cylinder mount. i am using heddmans by the way. would the hooker's give more clearance in this area?? i might be looking at cutting mine up to make them fit. any help would be appreciated, thanks.
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
The headmens are known to be a little close to the slave cylinder....try a search using headmen Lt's and a T5 that should get you some good pics. and info.
Good luck,
Mike
Good luck,
Mike
Hotrodboba400
Dec 10, 2019 07:07 PM
