dynomax ultra flo x muffler
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Has anyone tried this muffler? I'm just wondering if it will save space. Maybe put it where the cat would go.
JEGS High Performance - Dynomax Ultra-Flo X Mufflers
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Dynomax is awsome, I swear by them, its the only exhuast I will ever put on my cars unless I make 70k a year.
They are verry stock sounding but they flow awsome!!!
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Interesting that I saw this tonight. We just welded one up for my car tonight. I will put it on tomorrow and see how it sounds. I am running dual 3" exhaust with Moroso spiral flow 'mufflers' and it is a bit loud. Hopefully this will mellow it out a bit.
Put it up where the cats used to be. It is a bit long but not much more height than the 3" pipes themselves.
-Schultzy
-Schultzy
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
The drawback to that style muffler is that the "absorption" material eventually deteriorates and then it is VERY loud. Like the old glasspacks. Same principal.
Car: 1989 GTA
Well you may be right but 'very loud' is relative and this dynomax really mellowed out the sound. I frankly didn't think I could get dual 3" pipes this mellow.
Got the exhaust back on Thursday night. I'll post a pic. Don't have any good recording equipment but I'll try to take the laptop out to get a soundclip later. Mine might be a little different sound with the moroso's still on the car too.
-Schultzy
-Schultzy
Car: 1988 Pontiac Trans Am
Engine: GM Ram Jet 350
Axle/Gears: Moser 9" w/3.50 gear
Have you had a chance to record a sound clip yet? Using the X-flo where the CAT should be is the exact system I was thinking about building.
