exhaust ports and headers!?!?
Old Aug 22, 2006 | 05:18 PM
Justin86camaro's Avatar
Car: 86 Camaro
Engine: 350, aluminum heads, carb
Transmission: TH-700R4
Axle/Gears: 7.5 10 bolt, 3.42:1
hey guys i've hunting for the right set up for my 86 camaro 350cu. currently i have stock 73 heads with round exhaust ports ( 1.5" circle) with matching ( 1.5" circle) hedman shortie headers. i have looked into gmpp fastburn heads, trick flow, some edelbrock and brodix heads which advertise ( D shape exhaust ports). some edelbrock, and AFR advertise square port exhaust (1.5" X 1.5") now i can't find anyone that makes shortie headers for this port design. and i don't see any heads advertising the round port. is there something i don't see here or can i just not use edelbrock or AFR's on a third gen without using full length headers.
if anyone has run into this problem or have used some of the edelbrock heads or AFR heads on a third gen please fill my blank spots. thanks justin.
Old Aug 23, 2006 | 01:59 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Just find the right flanges for the heads, cut the old ones off and weld the new ones on your old headers...
On my Z24 i'm running round port flanges on D port heads (larger than LT1 ports).. i welded a bit extra on the flanges and used my die grinder to smooth out the transition.
Old Aug 23, 2006 | 05:09 PM
Car: 86 Camaro
so the 1.5" round port hedders are larger than the D ports? because i have the round flange headers will they work with D port heads?
Old Aug 24, 2006 | 12:18 AM
Engine: 450HP 355
Transmission: TH350
they will work as long as the mounting holes line up.. flow won't be optimal if there is overlap. Generally you want the header primaries larger than the exhaust port.
In my case i just modified the round ports but there wasn't much of a difference between them and the D ports on the heads. There was about 1/16" of overlap and i just rounded the transition a little.
here is a pic of the gaskets i used VS the head.. http://www.superdave81.com/Z24/gen2gasket.jpg
Old Aug 24, 2006 | 06:10 AM
Car: 86 Camaro
ok thanks , i might look into doing that as well. i appreciate it
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
