flowmaster single chamber mounting location ?'s
Old Aug 29, 2006 | 07:36 AM
pmpnavt's Avatar
Engine: L98 350
Transmission: 700r-4
i would like to mount a single chamber flowmaster on my car. right now i have the eldelbrock TES headers, TES Y pipe, no cat, Edelbrock cat back.
i would like to retain the dual exit while using this new muffler
In order to get this muffler to work on my car I was thinking 1 of 2 things
1. to cut the Y pipe where it joins together at the end of the Y pipe and run dual pipes side by side down the torque arm, over the axle and then tuck the two mufflers where the exhaust pipes exit next to the trunk.
2. put the 10 series muffler where the cat goes right after the Y pipe, leave the single pipe up to the rear axle, split it into 2 pipes there and run 2 pipes over the axle, then run them out the back on their respective sides. this setup would eliminate the need for a "X" pipe i would hope.
i know that #1 will work but its quite a bit of money and weight. Does #2 sound like it would work? if it would any suggestions on the routing and what to use to split the pipe again?
thanks
Old Aug 29, 2006 | 12:20 PM
pmpnavt's Avatar
Engine: L98 350
ttt
Old Aug 29, 2006 | 07:30 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
https://www.thirdgen.org/forums/exha...ml#post3041429
reply'd to ur first post about it.. any other q's feel free to ask, i can dig up more pix to if u like..
mike
Old Aug 29, 2006 | 08:37 PM
pmpnavt's Avatar
Engine: L98 350
your exhaust is great, but im trying to retain use of my edelbrock headers/ y pipe. would putting the muffler where the cat was stock affect sound/performance?
Vintageracer
Jan 10, 2020 05:33 PM
formula_novice
Sep 5, 2015 03:58 AM
Navy8125
Aug 25, 2015 08:25 PM
midias
Aug 22, 2015 01:42 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
