PAINTING HEADERS
Old Aug 30, 2006 | 07:14 AM
graphicideas1's Avatar
PAINTING HEADERS
does anyone have a good method to paint headers - they are newer and not rusted
Old Aug 30, 2006 | 08:24 AM
j dezzy's Avatar
Car: 87 TA
spray on high heat low gloss(or high, which ever you prefer..) enamal. can be bought at any auto parts store for a couple bucks.
Old Aug 30, 2006 | 08:28 AM
i have tried that in the past - has anyone had a good experiance with spray cans? How long has it lasted?
Old Aug 30, 2006 | 08:33 AM
j dezzy's Avatar
Car: 87 TA
I've used that enaml on all my engine parts and the engine bay itself. never had an issue, no cracks or peeling.
Old Aug 30, 2006 | 08:37 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
I used POR-20 on mine...Holding up pretty good so far.
Old Aug 30, 2006 | 08:52 AM
j dezzy's Avatar
Car: 87 TA
I've used POR 15. but what's POR 20?
Old Aug 30, 2006 | 09:04 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
POR-20 is for high temp.....exhaust, headers, etc...I think it comes in 3 colors...black, aluminuim, and manifold gray
Old Aug 30, 2006 | 09:10 AM
j dezzy's Avatar
Car: 87 TA
ahhh...thanks, I'll have to look into it.
Old Sep 3, 2006 | 09:57 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
Engine: Aluminum Brodix-block SB 427
Transmission: Turbo 400
Axle/Gears: Moser 33 Spline 4:10
I always used BBQ paint. It's cheap and it holds up better than that duplicolor with ceramic high temp paint that they sell at all the parts stores.
Old Sep 4, 2006 | 12:54 AM
Demon355's Avatar
I use the VHT stuff. Works pretty well I think. I have it for my headers, TPI parts and brake calipers. I'm going to look into that POR-20 though...
Old Sep 4, 2006 | 02:52 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sand blast them first... it gets the metal absolutely clean, and gives a really good abraided surface for the paint to dig into. Then paint with high quality header paint with at least a 1200* rating.. like from DupliColor or VHT. Then follow the instructions for baking the paint, or use a propane torch to bake it on.
Getting the headers sandblasted makes it so much easier... much better chance the paint will stick because the metal is perfectly clean, and its also a rough surface that gives the paint something to adhere to.
Street Lethal
Apr 30, 2019 12:14 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Dyno Don
17
Nov 2, 2015 11:43 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Sep 8, 2015 03:38 PM
