What can i use for a L69 manifold??
Old Aug 30, 2006 | 11:30 AM
Project84TA's Avatar
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
hey, ive looked all over and i cant seem to find an exhaust manifold for an 84 T/A w/ an L69. i was just wondering if i was informed correctly, i was told that the L69 manifolds had larger outlets then that of an LG4. i looked at gmpartsdirect.com and various other online stores. i just want to afferm that the manifolds are diffrent from a L69 to a LG4.
Joe
Old Aug 30, 2006 | 12:59 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Yes the L69 manifolds are bigger and flow better than Lg4's. I think the size at the collector is 2.25 inches for the LG4 and 2.5 inches for L69. I also think that TPI maniflods are the same size as the L69.
Old Aug 30, 2006 | 03:48 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The L69 manifold outlets are larger than the LG4. The TPI manifolds have the same size outlet as the L69, but IIRC the emission pipe is facing a direction opposite the L69. Also, the TPI manifold won't have the heat stove on the driver's side.
JamesC
Old Aug 30, 2006 | 04:41 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The higher HP 5.0 TPI and 5.7 TPI used the same exhaust manifolds as the L69. The lower HP TPI 5.0 used the smaller ones.
Old Aug 30, 2006 | 08:00 PM
JamesC's Avatar
Interesting. I was under the impression TPI's, in general, were equipped with the larger manifolds.
JamesC
Old Aug 30, 2006 | 08:58 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
I have a set of the L69 manifolds.....$5 plus shipping and they are yours.
Mike
sailtexas186548
Feb 17, 2017 03:07 PM
PurelyPMD
May 5, 2016 04:57 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
