patching exhaust hole
Old Sep 11, 2006 | 07:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I drilled a 7/16" hole in my y-pipe, and welded on a nut, for an O2 sensor. Once I put the exhaust back on the car, the spot just happened to be ~1" away from the SFC's, so i'm going to have to patch it, and redrill.
Assuming I can successfully use my angle grinder to remove the nut, and reweld it elsewhere, and drill the hole again -> What can I use to patch a 7/16" hole? I have a little stick welder, which I don't think is particularly easy to use to fill holes. Muffler cement? Put a patch on it and weld it?
Old Sep 11, 2006 | 11:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A piece of exhaust pipe, cut to slightly larger than the hole, welded around to seal it to the header pipe.
Old Sep 12, 2006 | 01:23 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
best bet would be to put a bolt in there with the proper sized threads and some never seize on the threads of the bolt and call it a day.
Old Sep 12, 2006 | 10:30 AM
Sonix's Avatar
Car: 1982 Trans-Am
hmm, that would be easiest xpndble, but I'd need a super short M18 bolt for that, I have almost no room in front of the nut, hence why I can't use it for an O2 sensor...
I'll try and find a short piece of 3" exhaust pipe, and make it into a band aid then. Maybe I can find a new M18 nut while i'm there too.
thanks
Old Sep 12, 2006 | 11:57 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
jegs or summit sell 02 sensor plugs or maybe your local parts store.
Old Sep 12, 2006 | 12:03 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Might not work/be the kind of fix you want, but I just recently fixed my little beater Escorts exhaust with a soup can with the top and bottom cut off, and cut down the side. I put that over the leak, hose clamp it, and no more exhaust leak. I've fixed a few holes in exhaust systems that way. It looks crappy, but it functions just fine.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
