Y Pipe questions
Old Sep 30, 2006 | 09:20 AM
350ChevyMania's Avatar
Y Pipe questions
So I broke part of my Y pipe since it brittle on the end and now it's too narrow at the end that it slips out of the bracket to connect to the header.
With only one header hooked up and a broken cat hanger, it's too low to drive now.
My questions is, I have a pair of shorty headers, but I think the rest is stock. Is it possible that the Y pipe is stock too? Could I just buy another Y pipe that's from a stock setup then?
Old Sep 30, 2006 | 11:16 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
they need to be matched with the headers. You cant stick just anything on and expect it to bolt up.
Old Sep 30, 2006 | 12:00 PM
So the Y pipe isn't stock
What are my options here? How much would an exhaust shop charge to get a Y pipe done?
Old Oct 1, 2006 | 12:02 AM
Is there any type of joint or clamp that would put a flair back on the Y pipe to hook up to my header? The flair on mine is broken and just looking for a cheap fix now before I replace it all.
Old Oct 3, 2006 | 11:50 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You need a friend with a welder. Anything metal is fixable. My header flanges were rusted out and they don't go on easy once the pipe is flanged. I had to cut them in half and weld them back. but I used two flanges this time and over laped them for a thick flange.
Other wise the Y pipe would need cut and re flanged.
Once ya get a welder, ya won't know how you lived without one.
Old Oct 3, 2006 | 11:56 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ok here is a cheap hooptie fix.
Put the flange clamp back on the pipe, The use a hack saw to cut even depth cut in the pipe. Then bend up the little tabs. Then use a bunch of 15min quick jbweld to seal it back together. Gotta use quick, reg will run and drip.
Or something similar. Goop jbweld on a pipe and jam it in that pipe.
Now that I got a welder I don't have them problems. But JB weld works good on exhaust stuff, I never liked using clamps that deformed stuff. Just gotta use the quick jb weld.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
hectre13
Sep 8, 2015 03:38 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
