Stubborn Y-pipe
Old Oct 15, 2006 | 04:00 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Stubborn Y-pipe
Hey guys, Im doing a oil pan swap on my L98 car,
and Its required that I drop the Y-pipe for clearance.
During the operation, I un-bolted the flanges and I
thought the Y-pipe would come crashing down on me
...tho I wish it did
I have Hedman shorties/ w The Y-pipe and ball/socket fittings.. And I cant get the Y-pipe to free up and drop to ground, Im only 20 yrs old and weigh 160lbs.. I cant get enuff leverage to break the sealed fittings.. And I definately dont wanna damage my new headers or Y-pipe..
Im irritated, anyone have any tips/suggestions?
Old Oct 15, 2006 | 04:23 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
If its rusted on there usually the simplest thing is to heat it with a torch evenly and give it a shot( itll be freeeking hot so use gloves and safety **** u dont wanna get burned), of course im sure a prybar would get the job done with enough wd-40 but.. dont wanna damage the flange lol
Old Oct 15, 2006 | 04:29 PM
TPI's Avatar
I think the thing is.. Its a brand new system, Paint is still prevelant on the headers and y-pipe.
I should have removed the paint on the sockets, So they wouldnt fuse together.. Now Im stuck battling a simple operation of removing a pipe.
Ill try to get some penetrating fluild up in there
and let it sit.. But I really dont want to pound my $500.00 exhaust system.. Its brand new, with no less than 10 miles on the motor/exhaust alone..
..then I damaged my pan like a fool
Old Oct 16, 2006 | 06:18 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Rubber hammer or dead blow hammer on a cool exhaust.
Old Oct 17, 2006 | 05:07 AM
TPI's Avatar
Yep, It was the paint causing it to stick together..
With alittle tough love, it came off just fine, and the
pan has been removed/replaced.
Thanks for the suggestions
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
